Mr_Roboto
Yea, that funky adaptor is missing on my "new" 6.9L. You can tell pretty easy because the line is bent wierd to connect. It also looks cross threaded onto the injector.
Am I correct that having a shorter line causes that cylinder to have advanced timing relative to the other cylinders? The motor is making a nasty noise at higher speeds.
I guess I'll get a van injector line for that cylinder, I figure the replacement line is easier to source than the adapter.
