Timed Switches... Send me to school
D_Fresh361
Victoria, TX
working on a project that is having some heat soak/temp rise after the engine has been cut off leading to hot start issues.
Plan is to install an electric fan to aid in cooling after the coolant system and flex fan or no longer able to do their job.
My question to y’all, is there a toggle style switch that is timed? Apply power, walk away and switch cuts power after set time, what that may be preset or whatever.
What do I need here? Don’t really want to go the sending unit route that operates off of temperature/on - temperature/off.. is this my only option?
Thanks for any input.
Thewespaul
Bulverde, Texas
Is it the mustang? If so its probably just your starter getting heat soaked with your headers if its not cranking fast after heat soaking. Put a mini starter on or a heat blanket, had that exact issue with a big block ford and headers.
D_Fresh361
Victoria, TX
Indeed it is. I will check into this. Thanks for the direction man
raydav
Apple Valley, CA
My turbo is remote mounted on the frame. I have a scavenge pump to return the oil to the engine.
I made a turn off delay for it. Turn on "ignition", the pump starts. Turn off, and the pump stops a minute later. The pump is controlled by a power transistor. The delay circuit is just a resistor, diode and capacitor.
dgr
sac town
... The pump is controlled by a power transistor. The delay circuit is just a resistor, diode and capacitor.
Student:. Where will I ever use math?
Raydav:. Watch this
This is a very cool solution. Does the pump also take the cap charge time to turn on when you start the truck?
raydav
Apple Valley, CA
Raydav:. Watch this
No, it is kinda like a check valve; instant turn on and slow turn off. The cap is charged thru the diode and bleeds off thru the resistor.
And it is slightly more involved than I said. I did this years ago and kinda forgot. There is a small transistor, diode, resistor and cap that form the turn off delay, and that drives a large buffer transistor.
Cv axle
