Tie down hook
nelstomlinson
Delta Junction AK
Haven't done it yet, but my plan is to put some stout angle iron on top of the bed sides and across the front, maybe 2x2x3/16 or so, then weld on some d-rings to the vertical side of the angle, which would be sticking down inside the bed.
Here's a cross section through the top of the bed side:
Cant Write
Placerville CO
Good points, my trailer is nothing nice, and we always used rope to tie down growing up. Cleats were great for that, and loads above the bedsides, like evergreen bushes and green waste like that.
I like the metal angle iron cap idea and have day dreamed about it. Then tying it down the sides into the floor and then......well might as well buy a dump trailer at that point cookoo
tbowker
Hudson, Florida
I have something similar to what you described. I'm considering welding some D rings to the steel plate that's bolted to the bed for lower attachment points.
Maybe, except that you already own the pickup bed trailer.
I used to have a combination headache rack/bed rails like that years ago. It didn't have the expanded metal behind the rear window. but it looked pretty close otherwise. I did like it, but I don't remember what I ever did with it. I may have transferred it over to the 1975 F250 that I had for a while and let it go with the truck.
My 22ft steel deck car trailer has 4 of these flush deck tiedowns. Not sure the strength of them, I usually use something more substantial when tying down a vehicle on the sides of the trailer.
In the bed of a truck, they could get packed with dirt etc... and rust.
Then there are these tracks that are pretty cool.
Did a Google search on the steel track tie downs. HF also sells these things also.
