94turboidi
Okay well some of you might know of all the stuff I have recently went through on the truck. Anyways I have a new clutch set on the truck which included throwout bearing and pilot bearing. I was having trouble getting the clutch to disengage until I put an adjustable pushrod on there and it worked. I need to replace the pedal bushings sometime but haven't got around to it yet. After maybe 100 miles or more of driving the truck a slight squeaking noise started. At first I thought it was on the engine but when I push in the clutch pedal just slightly it goes away. I wouldn't think a brand new throwout bearing would be bad already?
The only other thing I can think of is maybe the flywheel to crank bolts have loosened up somehow but I don't feel anything weird when I am driving it. Should I just replace the pedal bushings and adjust the pedal to where the noise stops? Just to be clear I don't have to disengage the clutch for the noise to go away I just have to slightly press down on it. Its an embarrassing sound I have to push in slightly to make the noise go away when I am pulling up somewhere but I don't like operating all 3 pedals non stop just to drive in public.
I have a few other quirks with the truck but for the most part its drivable now.
