Throttle Cable Woes
Max Mini
Hey there, so sorry to drop off. I am dealing with a health issue for my Mom and have totally been focusing on that. I'm out of town all next week but will be diving into this when I return.
troutwest66
Ricer-Roni The IDI Treat
Post Falls, Idaho
Sorry to hear that. Hope all is well. Keep us informed.
Cubey
Van dweller
USA
Any update? It seems my RV's cable has stretched, so I need to consider replacing it now too.
Detroit80
Wittmann, AZ
No idea on the RV/van cables...but I can say that I had to both fabricate a spacer for the throttle pedal on my '90 pickup AND add a bunch of tiny zip ties to the pedal end of the cable to make it work right.
It's one of the aftermarket parts store cables, though I don't remember exactly which one now...I went through about 6 different cables trying to find one that wouldn't melt in a day from turbo heat (finally ended up shoving this one through a spark plug insulator wrap/boot that has the appearance of a metallic blanket on the outside), and it's been holding for quite some time without any hints of an issue.
But my spacer + zip ties have probably taken up 2-3 inches worth of excess inner cable.
typ4
Newberg,OR
Sounds like they gave you a 92 up cable.
SuperDave
douglasville
Just FYI for those of you that get stuck using an aftermarket throttle cable that is too long to get full throttle ( they all are). Use the crimp on lead fishing line weights they work a hell of a lot better than zip ties and whether you fish or not you probably have some somewhere, it usually only takes one maybe 2 and I have also fixed throttle cables this way when the pedal end broke off.
Cv axle
