middaymidnight
HX40 will be a better bet. The HX35 hot side is to small IMHO, it will be nice on the bottom end for spool, but high rpm's would result in high back pressure/EGT's.
Ditch the stock 12cm housing and go larger, they sell a 16cm/18cm non gated housing which would work better. The 21cm housing from one of the H1C's and a HX40 hotside might actually make a decent combination, although a little laggy on the bottom (but we have high compression so thats not as much of a problem). A stock HX35 will be like a 093 ATS turbo. It will make a difference, but it is not ideal (which is the case for any of the banks, ATS, or hypermax turbo kits).
http://www.gillettdiesel.com/turbochargerspartsandupgrades-3.aspx
$.02
My thought is, it will make up for the more restrictive hot side by boosting more, and I doubt it will be much more restrictive than the Mitsubishi turbo that's on there now..
