ocnorb
IDIT
That motor sounded awesome!
Id like to see all these wanna be pretty boy trucks do that, I bet they would get stuck every time even if they tried it at all.
I had something kinda like that happen once...went through a fairly deep mud puddle, and the engine started running REALLY rough. As soon as I got on dry ground, I shut the engine off and pulled the air filter out...there was mud on it and it was nice and wet, and there was a fair amount of sediment at the bottom of the housing. No water on the "clean" side of the air filter, thank goodness. Cleaned it out, let the air filter sun-dry for a minute or two, and the engine started right up and ran perfectly and no problems sincei cut a hole in the cowl, then ran the factory ford air intake tube to a pipe i screwed to it. after this run i went the other way through and the water splashed into the cowl and the truck stalled! though for sure i hydro locked it, bumped the key and it lit right off and made it through!
