flatlander
plays dirty when losing
I have found that of all the various petroleum based fluids in my truck antifreeze is definitely the tastiest. Nice sweetness and very little aftertaste. Diesel fuel starts out slowly and then has a long long aftertaste. Not so bad in the middle but I'm definitely ready for it to go away. ATF is a bit sharp but not entirely unpleasant, but motor oil--nasty. Of course it doesn't help that the motor oil is instantly blackened. It might be ok right out of the bottle but I prefer my tastings to be served one drip at a time while lying on my back in my driveway--the same driveway which is now colored by every liquid or semi liquid which is in my truck. Power steering fluid believe it or not is somewhat tasteless and mostly just makes you mad knowing that it's there.
Oh, I haven't had the pleasure of sampling gear lube simply I haven't had a reason to do any work with my head in direct line underneath it. Maybe I should do a little pinion adjustment for the fun of it.
