TECH 101 windshield re n re
I have been asked many times if I could do a tech 101 on windshield removal and installation, and it's a hell of a lot of work with many pictures but alas...today I did my best at it for ya'll
This is a method I use when I've only myself to remove the glass. With a helper you can use the piano/guitar wire too, and that's simpler, I may at some time insert that method into this thread at a later date, for now...one person knife method.
Though this is NOT on one of our trucks it's methodology and techniques apply just the same to us and many other vehicles of similar construction.
Thus we have Super's 89 Mustang convertible, which after doing several of this has to be without a doubt the easiest one I have ever done!
There will be basic stuff to do not covered in this as if you cannot figure out how to remove trim panels and inside trim, you should not be attempting this level or service work.
Remove outter windshield trim and wipers.
Remove inner trim and mirror and any other crap in yer way...dash bobble heads and hula girls for example!
On to tools needed
Exacto knife...and LOT'S of blades, having a super long knife like the one shown is extremely helpful and worth while addition to the tool box...another reason to spend $$ on tools..but honey..I need it to keep my cost of windshield repair down hint hint...
LOTS OF BLADES
LOTS OF BLADES
LOTS OF BLADES
Just in case I have not said it enough...lots of blades...some bandaids could be of help too...depends on how accident prone you are.
THIN cotton gloves...you'll learn why if you don't use or have any! I forgot this time and paid the price!
If you are going to remove a good windshield from say a wrecker and don't mind gooey mess, LOTS of WD40 or other lube...spray on butyl and cut..spray cut...lubes blades...soapy soapy water works too!
What is often referred to as a paint roller tool...aka trim removal tool to those in the know
So tools
Blades, one or two or more exacto knives,
WD 40 or soapy water
Paint roller tool
flat screw driver
some type of surface prep tool grinder and heavy scotch brite wheel
good quality calking gun, pnumatic or cordless are ideal
get primer at glass shop for windshield frame and windshield
A couple of suction cup dent pullers are super handy!
Painters tool and how you can get under clips and pop trims
After removing all trim inside and out I start by removing the excess sealant on the outside of the glass as shown
Here roof up...easy access all trims removed
Cleaning out the outside gunk
Here you can see that I've cut back the sealer and am pulling it out
No sealer outside of glass...already hard enough to cut this out...more sealant makes it harder
continuing on cutting 90 deg to windshield to remove the crap..
The screw driver if narrow enough will fit in under the sealant after being cut and help lift up and you can remove it all out so it looks just like this now
Ahh...corners are the worst
Ahh...ooooo....aaaaaaahhhhh long knife makes dash work and corners a breeze
Here working on the inside I'm trying to keep close to glass on a bad windshield...close to frame if it's a good one I'm cutting out
More to come
On to tools needed
LOTS OF BLADES
LOTS OF BLADES
LOTS OF BLADES
So tools
Paint roller tool
flat screw driver
More to come
