take apart door hinges
w4dsb
loganville ga
cut mine in the middle with a right angle die grinder and a cutting disc , then pulled them out each way up and down
RyanDamo
1 IDI 2 Strokes
Shelton CT
you can use a chisel if you cut them in the middle, that prys them out enough that they pop out.
fury9
island lake il
I ground the top or bottom (whichever was easier) then used the new door pin to beat it out. try not to take the hinges off the door or body. They are a real PITA to get lined up right again.
Cv axle
