Switch to IH Crew cab questions
Duke
PA
kblackav8or said:
I think it is about getting a DT 466 as much as anything. They sound impressive. I would also be fine with the CAT and probably the Cummins as well so a F-650 would also work as well. I kind of like the IH crew cab design with the amount of space, the doors and the fact they haven't made any huge changes for long periods of time. I realize the new ones look much different but for a long time that cab remained basically the same. Does IH make the entire truck for Ford to just make the frame/drivetrain and assemble the rest?
IH makes the chassis for Ford in the Blue Diamond Joint Venture plant in MX.
The 4700/4800/4900 is a better work rig than the 650/750.
The DT466 is very quiet at idle or when out on the road.
nevrenufhp
torque ******
Sacramento
Not too quiet when they're cold. Still not bad, I'd say it's like a 12 valve Dodge in overall noise.
Duke
PA
Surprised to hear that. Mine is much quieter than my neighbor's 12V when cold :backoff , and it gets down to 10 degrees out here.
kblackav8or
Stationed San Diego, Oregonian
I spent a few minutes and speced out a F-650 crew. Hopefully this pastes in OK>
Window Sticker 2007 Ford F-650
Crew Cab XL
Major Standard Equipment
Cummins 5.9L I-6 OHV w/diesel injection 200hp
5 speed automatic trans w/OD
4-wheel ABS, hydraulic disc brakes
10.0R22.5 highway tires
M+S rear tires
Air conditioning
Tinted glass
AM/FM stereo
Variable intermittent wipers
22.5" x 7.5" white steel disc wheels
Tachometer
High back driver captain seat, mid back passenger two person bench seat
Full folding rear bench seat
Vinyl seats
1,250 Amp dual batteries
130 Amp alternator
Side steps
45gal. right front fuel tank
Multi-leaf rear springs
8,500lbs. front axle capacity
17,500lbs. rear axle capacity
8,500lbs. front spring rating
18,500lbs. rear spring rating
12.64cu.in. frame section modulus
50,000 frame yield strength (psi)
194.0" wheelbase
84.0" cab to axle
49.0" axle to end of frame
282.0" overall length
Heated fuel/water separator
Transmission PTO provision
Right mounted horizontal muffler, right mounted horizontal tailpipe
Dual electric horn
Selected Optional Equipment
Base Vehicle Price $51,922.00
19,000 lb. Single-Speed - Spicer 19060S $366.00
3.70 Axle Ratio N/C
Air Brakes - Straight Truck w/16.5x7.0 Rear Brakes & Traction Control $1,646.00
Caterpillar (7.2L) C7 300 HP @ 2200 RPM, Governed @ 2400 RPM $7,012.00
Engine Exhaust Brake - Jacobs w/Caterpillar $915.00
Fuller FS0-8406A, 6-Speed Manual, Overdrive -$1,598.00
Synthetic Transmission Oil, EmGard 50W - 1 thru 21.99 Pints Included
Two-Plate, Stamped Angle Spring, Ceramic, 14" Diameter, Adjustment Free Clutch $457.00
Body Builder Wiring - To End of Frame $134.00
Tank - Steel (Shallow) 65 U.S. gal./45 U.S. gal. Combination - Total Capacity 110 U.S. gal. (416 L.) $593.00
22 Gal. Dual Tank Fuel Fill. Mandatory Charge Applied, Based On Tank Selection $0.00
Air Ride Driver, 30%, Reclining, G-Grain Vinyl w/G-Grain Vinyl Insert $463.00
Passenger Air Ride, 30%, Reclining, G-Grain Vinyl w/G-Grain Vinyl Insert $415.00
Rear Bench, G-Grain Vinyl w/G-Grain Vinyl Insert Included
XL Trim Package N/C
Privacy Glass/Sliding Rear Window $244.00
Horn, Air, Grover - Black, Single Trumpet $55.00
Mirrors, 2 Auxiliary Convex - Stainless Steel $43.00
Mud Flap Holder Without Flaps $79.00
Mud Flaps, Rear $67.00
Radio CDX6 AM/FM Stereo - Visteon w/6 Disc Changer, No Cassette $561.00
Steering Wheel - Two Spoke, Black Leather Wrapped, 15.5" Dia $85.00
Wheels, Front 22.5x8.25 Polished Aluminum Disc, 10-Hole $567.00
Tires, Front Two 11R22.5G Goodyear G395 LHS (504 rev/mile) $24.00
Wheels, Rear 22.5x8.25 Polished Aluminum Disc, 10-Hole $1,171.00
Tires, Rear Four 11R22.5G Goodyear G395 LHS (504 rev/mile) $24.00
All for a grand total of $66395
I would tweek a few other things before ordering such a thing. Probably would spec the rear tires for something with some traction capability. I wish they had 2 speed rear axles with something like 3.50 and 4.33 as the split. I don't know if IH has a built it online but I will look. A CXT would be awefull cool though.
nevrenufhp
torque ******
Sacramento
All that truck and you only get a 5.9? Come on.....isnt the 8.3 an option on these? I think the IH may still be close in price, plus can come with a 466 ;Sweet
Duke
PA
HA!! That's Markinter's truck!! LOL LOL
Spec-out an '06 crewcab 4700, 300HP DTA466 and a transmission with an O/D gear. Then you'll be getting into a REAL truck. :draw
The best advantage IH has over Ford, other than it's just a better built truck, is the extensive dealer network IH has compared to Ford.
Availability of the 8.3 Cummins is sporadic on the F650/750. I think it's been discontinued. That's the diesel I'd go with in the Ford. Cat has too many problems.
Better off with IH on a new truck. If it's used, just buy the best truck for the money that's speced closest to the way you want.
Jarlaxle
Bregan D'aerthe
New England
BEWARE! F-650's with the C7 Cat are absolute dogs. I drive one at work (2004 F-650, 25,950 GVWR, rear airbags, 295/75R22.5 tires, 5-speed Allison), and it borders on dangerously slow, even empty. I'm also not thrilled with the cab...not a lot of storage, marginal heater, steering column too low (or wheel too big, take your pick--it's a larger diameter than an F-250/550 wheel), no adjustable-height seat belts, and the air gauge, cruise/RPM control switches, & air horn button are very poorly-located (obscured from sight by the steering wheel and/or shifter). I want an International. :(
nevrenufhp
torque ******
Sacramento
kblackav8or
I PM'ed Mark but haven't got back a response. He is a couple hours away. There are 3 issues with his truck though they aren't really deal killers - Mileage, Color and if I can make my Camper fit on it. I would like to see more and get some good details on it. Who knows, it may have already sold.
Duke
PA
A very plain work truck& very uncomfortable on log trips. IH bech seats are as crude as it gets.
I would suggest finding a truck already converted to a hauler to cut down on customizing expenses. 99.8% of all IH mediums are work trucks. 95% don't even have A/C. A lot of them don't even have shock absorbers.
You need to be patient and wait for an IH hauler or keep an eye on the F-650 crewcabs as they tend to be MUCH more comfy inside-better for long towing trips. It costs a small fortune to convert a work truck into something comfy for long trips. M
Since your truck is to be used as a personal vehicle & long trip hauler, my advice is to steer clear of former work/dump trucks. They're usually stripped to the bone, have base model trannies, low HP ratings and no interior refinement or AC.
