summer/pre rally upgrades....
no mufflers
rhode island
I figured I would share some of the upgrades or modifications I will be doing to my truck to prep it for use. some things are just typical maintenance and some things I am doing just because.
the most important things to do are,
-front brakes, including pads and calipers
-rear E brake cables
-new P/S gearbox
-reman P/S pump
most of this is already done
this is the interesting stuff. since I have the twin I beam you cant really buy a lift kit for it, not that I have seen. two years ago I bought 1.5'' lift blocks and it put the front end way out of whack and I was wearing out tires really fast. so I decided to make my own lift kit, it is only a 2'' lift but that is really all I need.
there are several ways to lift these front ends and its probably not the way most people would do it but this is what I decided to do.
I am having 2'' spacers made to go in between the factory lower spring mount and the radius arm.
I modified the radius arm brackets to be 2'' lower.
in stead of making brackets to lower the I beams I cut, welded and gusseted them.
all the front end parts have been sand blasted and soon to be painted. I hope all this works and it can now be properly aligned. pictures will be coming soon...
no mufflers
rhode island
alright il try to put these pictures in order
old gear box
new parts
new bushings
tie rods are all pianted
truck on lift
tie rods are ready for paint
new gear box installed
drums are all cleaned up
no mufflers
rhode island
Bronco /f150 lift brackets should drop the tib and lower radius arm brackets FYI...
just looked on rough country they have them for the 4x4 for $360, not too sure if it would fit. not a bad price either.
it looks like the radius arm brackets would work. oh well mine are already made.
Well seeing that converting a 2wd F150 to 4wd is as simple as removing TIB and replacing it with TTB then adding tcase drive shafts done...no reason those lift brackets and parts would not work on a TIB to give you correct steering geometery and lift.
JM7.3CW
Dieselcrawler
Professional wrench holder
Quakertown Pa
I have a set of drop brackets for the beams and springs that net 2 inch lift for a 2wd, both new in box..... Could of brought them to the rally. Lol
no mufflers
rhode island
here are the rest of the pictures I have so far.
old front end parts
this is the first beam I started on. it is mocked up to make the gussets
the finished I beam
I am holding the old bracket, the modified one is on the frame
dunk
Dunce
NJ
For all the effort to lift a 2wd... Why not swap in a D60?
No, it is an effort to LOWER the 2WD.
Nope...he is LIFTING it...re read it...spring spacer under spring....lifts front...not lowers it....no lift kit for 2wd....
Lowering the TIB and radius arm brackets and adding taller springs and shocks...lifts truck...
DaveBen
Ukiah, Ca
You are right, He is lifting it. I looked at the Eyelet he welded on the TTB and mistook it for the other end. My fork-up.
no mufflers
rhode island
I was thinking the same thing but I don't need a 4x4 truck. this is costing me nothing besides ALOT of labor time and I don't have much parts to do a D60 swap. the twin I beam will ride much better then a solid axel will.
dunk
Dunce
NJ
If you decide to go 4x4 I've got a dually D60 I've been tripping over for a while and not sure I'll ever do anything with.
no mufflers
rhode island
thanks if I need it il let you know. I have some friends that might need it.
fizzle
