i saw bottles of sulpher substitute at the store the other day has any one tryed this stuff? is it worth running or is there somthing that would work better
yeah looks about the same as other diesel additives. there is an additives forum on here that has good info. I really like diesel kleen and i also run some tcw3 two stroke for lube. Even helps the mileage some.
