Stud Length
Joe Mc
Loveland, Colorado
Why are my back studs longer than the front ones?
The back measured 2.25 inches while the front ones are 1.7 inches from the drum/rotor surface to the end of the studs.
The studs stick-out so far past the lug-nut that my 4-way lug wrench won't reach the nuts.
sle2115
NRA LIFE MEMBER
Southeast Ohio
Boy, right as I clicked on this, I thought, god please don't let this be the refinery! :rotflmao :rotflmao
I noticed that as well, I guess I assumed it was to accomodate SRW/DRW with one stud part number.
Mr_Roboto
Elyria, near Cleveland Ohio
All full floater axles use the same stud length, the longer ones are for dually trucks.
The factory lug wrench will fit, or use a regular deep socket.
Or if you really want to be able to use a 4-way, replace the original lugnuts with deep closed end nuts.
Joe Mc
Loveland, Colorado
It is good to know that the lengths are normal, at least for the 6.9 forum.
I like the 4-way for breaking the lugs loose, but I keep a deep socket for the speed wrench and the torque wrench.
Thanks for the help!
