Let me start off by saying I am about as good at wiring as Britney Spears is at singing . The previous owner of my truck wired in a push-button system to bypass the solid state controller. I assumed it worked. (Never assume!!! ) So, I go to start the truck for the first time with the new motor. It took 10 minutes and starting fluid, but it fired up, and ran quite nice one all of the air had purged the lines. I've had to start it 2 or 3 times since then to move it around in the driveway (no exhaust or turbo on it yet) and the glow plugs don't work. Pushing the button on the dash doesn't even dim the lights or move the voltmeter. But a quick shot of ether the few times I've started it and it fires right up. I've ran it for close to 10 minutes (pissed the neighbors of with straight manifolds) and it runs great. So from that, and checking all of my fuel lines, I can rule out air leaking as a possible contributing factor.
So far, I've checked the fender mounted solenoid which is controlled by the push-button, and the wire leading from it to the glow-plug controller. When the button is pushed (whether the ignition be in run or acc) 12.something volts is present, so I know that works. I've used a test light and ohmmeter to check the glow plugs (which all lit the light, and all had .3 ohms of resistance cold, or was it .03? One of those) I even pulled a few out and they looked brand new!!! (I put them in when the engine was on the stand about 4 months ago. I checked the PO's wiring against the tech article here on bypassing solid state controllers and it all looks to be correct.
Here's the weird (scary) part, I've found, using a multimeter, that with the Ignition on run, 12.something volts is Constantly present at the terminal on the controller across from the always hot terminal!!! (I'm talking about the one momentary power is supposed to go to) And this is with NO wires going to it, including the white wire (which was taped off) or the wire from the solenoid/pushbutton setup. Furthermore, with the ignition in run, and all of the bullet-connectors disconnected, I've checked each one (connector) and they all read 11.6V constantly!!!
I am amazed (and still a bit skeptical ) that my glow plugs are still good, but 2 tests and an eyeball check (I've seen burnt-out plugs with swollen tips before) seem to confirm this. All of this being said, I am not very good at electrical stuff and could use any tips/suggestions you more-experienced wrenchers can provide.
Thanks in advance,
Peter A
Thanks in advance,
Peter A
