BIG DAVE
OILBURNER FOR LIFE!
How can I adjust my steering wheel so it will be straight when i'm going down the road? It's driving me nuts
Is the truck driving straight if you let off the wheel? Or it tends to pull to one side, and you have to hold the wheel turned slightly to the other side to counter the pull?
If she goes straight and just the wheel is cocked to the side you'll have to stretch one of the tierods and shorten the other one by the same amount - say your wheels is 30 degrees to the left, you should lengthen your driver-side tierod by turning the adjuster sleeve between 1/4 and 1/2 turn, and then you should shorten the passenger-side tie rod by the same amount. I can't tell you which way to turn the adjuster sleeves tho, but you'll figure it out when you crawl under the truck and examine them carefully.
While you're in the slow lane too? And you hold the wheel a bit to the right to counter it, correct? What if you get in the hammer lane on a divided freeway with a wide grass area between both directions of traffic, does she pull stronger to the left then, and you gotta hold the wheel more to the right to keep her going straight?It pulls the the left alil bit.
I hate I-beam's
me too, esp. because my camber is messed up too...I understand that is hard to fix with the I-beams, I think it involves bending them
The closest freeway is 4 hours away lol but it always pulls to the left alil and yes i hold it to the right.
They make adjustable upper ball joints for them.
O===O
