rhkcommander
Ordered a Powermaster starter back in october 2013, Found the dyno for it in my garage. Starter tested in March 2013.
Part number 9050
Part number 9050
Performance result:
Max Torque: 36.2 Nm
Max Current: 756 Amps
Max Power: 2.80 kW
Speed @ Max Power: 897 RPM
Current @ Max Power: 657 Amps
Torque @ Max Power: 29.80 Nm
Ratings:
Rated Voltage: 12.0 V
Rated Power: 3.5 kW
Ground: NEG
Pinion Teeth: 13
Rotation: CW
Simulated Battery: 775 CCA
P/N: 9050
Type: OSGR
Model: Denso
Commutator / Brush Ripple Pattern
Ripple Current: 11 Amps
Analyzed at: 1200 RPM
Free-run results
142.5 A @ 4595 RPM
Solenoid results (* compensated at rated V)
Pull Current: 55.23 A*
Hold Current: 19.51 A*
Voltage Drop (Max): 0.00 V
Close Test (Pull in): Pass
Open Test: Pass
