Starter Dyno Sheet for Powermaster 9050
rhkcommander
Oregon
Ordered a Powermaster starter back in october 2013, Found the dyno for it in my garage. Starter tested in March 2013.
Part number 9050
Performance result:
Max Torque: 36.2 Nm
Max Current: 756 Amps
Max Power: 2.80 kW
Speed @ Max Power: 897 RPM
Current @ Max Power: 657 Amps
Torque @ Max Power: 29.80 Nm
Ratings:
Rated Voltage: 12.0 V
Rated Power: 3.5 kW
Ground: NEG
Pinion Teeth: 13
Rotation: CW
Simulated Battery: 775 CCA
P/N: 9050
Type: OSGR
Model: Denso
Commutator / Brush Ripple Pattern
Ripple Current: 11 Amps
Analyzed at: 1200 RPM
Free-run results
142.5 A @ 4595 RPM
Solenoid results (* compensated at rated V)
Pull Current: 55.23 A*
Hold Current: 19.51 A*
Voltage Drop (Max): 0.00 V
Close Test (Pull in): Pass
Open Test: Pass
Part number 9050
--I will be attaching a scan of it ASAP--
Six tests were done, too much info to try and fill here without a chart capability...
How bout a PRICE ....how much did this bad boy cost ya?
rhkcommander
Oregon
Dyno sheet added, had to do some contrast/brightness adjustments and edited out my shoe-print LOL
Cost me ~130 IIRC, on sale and "lightly used" - probably just open box:dunno
Looks like its about 200$, but a thrifty person could get it cheaper :dunno
I e-mailed powermaster and asked what made it so special versus regular denso's, I will try to drum up those conversations
rhkcommander
Oregon
Here is the graph color-coded to help anyone having a rough time seeing what is going on.
E-mail message
Hello, I am interested in purchasing a new starter and found out about the 9050 model. Looked around for information but not much was available. The torque for OEM Mistubishi and Denso starters do not list their torque, but do list power rating. The Denso is rated for the same 2.5KW as the Powermaster 9050.
Are there any real differences?
Reply
The accuracy of the rating and quality of parts is the big difference. I can tell you that the Powermaster starter is very thoroughly dyno tested and proven to surpass our advertised torque rating.
All in all, I've been very happy with my starter. I cannot say if there are any internal differences, there were some minor differences outside but I can't find any before pics :eek:
