Thought this data might be interesting -- No problems, just checking some test equipment. It's starter amperage, cranking voltage, and glow plug amperage. Test data is from a 1988 7.3L with Mitsubishi starter, Ford glow plugs, and NAPA glow controller.
Initial conditions, battery 12.54 V (SoC), 41 F ambient, block temp 39 F, not started for 12 hours.
* The voltage drop between Bat + and the glow controller (2 yellow wires) was roughly 0.9 v drop at 150 A (~0.6 V drop for every 100 A). Significantly higher probably indicates a bad connection (there is a multi-pin connecter C-129 on the RH fender for these wires).
** The cold cranking amp (CCA) rating refers to the number of amps a battery can provide for 30 seconds at a temperature of 0°F until the battery voltage drops to 7.20 volts for a 12V battery. When batteries are wired in parallel (like these trucks), their ampacity doubles.
650+ starter Amps @ 10.41 Volts minimum (no Glow amps).
Warm test, block temp 180 F:Cranking speed was good. Peak amps during cold cranking went as high as 1200 amps, but this is probably for only a fraction of a second during the initial engagement (and the meter is only spec'd to 1000 amps). After testing, it was started normally and fired within 1-2 seconds. Batteries (2) are rated @ 930 CCA, and tested @ 1020 and 1000 CCA ** (Large Pulse method-temperature corrected, Argus Analyzer).
Initial 370+ Glow plug Amps tapering to ~150 (18.75/plug) @ 14 seconds (WTS light out). A second meter was on an individual plug as a cross check.
The battery dipped to 11.4 volts *. Note that this glow amperage measurement was made at the 2 wires feeding the glow system below the starter solenoid on the RH fender. Troubleshooting Idea: The reading on one plug should equal the total reading divided by eight if all the plugs are good (and have equal resistance). The amperage is a moving target, so take the total amp reading just as the relay clicks off. Wait a few minutes, move the meter to a plug and repeat. If making a measurement using the larger wire from the battery terminal, subtract the non-glow amperage (about 10 amps) from the reading. It's not precise enough for comparing with a single plug, but access is easier.
410 starter Amps @ 10.73 Volts minimum (no Glow amps).
Initial 310+ Glow plug Amps tapering to ~150 @ 7 seconds (WTS light out).
General Notes:Even though the engine was warm, the hood was up and ambient temp back at the glow controller was probably still in the 40's. The glow controller may be designed to sense ambient temperature and change the amperage setpoint when glow heat turns off, and/or eliminate glow heat at higher ambient temps. Different controllers may use different methods, but in any case the plugs increase resistance and decrease current as temperature increases.
