Southerns and westerners...
metalminded
ny
I live in NY and the rust here is rediculous. I am looking for a good OBS extended cab frame and possibly a cab . My truck is a 96. I have my own freight shipping setup. I just need someone knowledgeable on the ground to source me a good rust free frame. I am willing to pay someone in a friendlier climate to help me find one.
Please pm or email me if you are interested
Thanks ahead of time
FarmerFrank
Blairsville, Pa
How about an 86 extended cab frame in western Pa?
metalminded
ny
That was a quick response!
I would really like to try and find a 96 or 97 so everything swaps over nice n greasy.
I would also take a rust free truck with a bad drivetrain....
FarmerFrank
Blairsville, Pa
I understand. Should be too much different between the two if you go bare frame to bare frame.
FarmerFrank
Blairsville, Pa
It made me chuckle because I just took the cab off it and was waiting for the buyer when I decided to see what was happening on oilburners...
Contact a member by the sign on name Towcat. I know he can "fix you up" because he often cuts up and crushes rust free rigs. He is in Ca mid state area.
I have a 96 crew cab with a good frame and a partial stripped cab....
FYI the only real difference inbetween these generations of trucks is the front bumper mount.
easily fixed with a good welder.
Kizer
Denton, Texas
I too am curious about this....
About when did they change thickness?
I believe it was between '84 and '85. Can't prove it right now, not sure how to look it up yet.
for S&G's
I decided to go outside with a wire wheel on a drill, a tape measure, and a set of dial calipers.
I measured 4 different trucks.
right behind the rear cab mount, as this is where they all were pretty similar
all 4 frames were 37.5" from outside to outside of the frame rail
tyoe pf truck frame heighth and width frame thickness
85 F250 4wd SC LB 2.5 x 7" .225"
87 F350 4wd CC LB 2.5 x 7" .250"
96 F350 CC LB 2WD DRW 2.75 x 7" .250"
01 F350 4wd CC SB 3 x 7" .250"
