SON OF A B***H
benton
Country boy
Bushkill Pa
i was un bolting my torque converter and i stripped one of the damn nuts-cuss any ideas on how to get it out its tight as hell down there already! and i really dont think burning it off is a good idea even tho its a **** converter!
Snap on socket or a good quality one and then sand down the chamfer to get full engagement.
Fordman75
Lonsdale, MN
Did you just round off the nut or strip out the threads? If it's just rounded off I usually use a cold chisel and a hammer.:backoff :D
dsltech83
Ellery,IL
What size did you use? A good quality 6 point socket should get off anything thats not totally rounded off.
benton
Country boy
Bushkill Pa
i used the right size! its a 9/16ths socket i was usein all the others came off great. but the last ones all ways a *****! im probly goin to chisel it off if i cant get it off tomarrow!
greasemonky
White House, Tn.
I have used these on a rounded converter bolt before, alone with other rounded bolts. They work great. I bought them at my local parts house.
Brimmstone
I have several sets of those in snapon and mac flavors. Bought the first set years ago when a convertor bolt rounded off in an explorer. I drove the socket on with a hammer and then used a 1/2 inch ratchet to break it loose and then back it off. They are worth their weight in gold in my opinion.
yARIC008
Drives really slow
Orlando, FL
I have a plasma cutter for such instances. If i were closer I would help you out ...
Simp5782
SNOW TACKLER!
Western MT
carbide blade for a reciprocating saw and just cut the flexplate and buy a new one or junk yard they are cheap
