Thefarmboy21
Ok so here's the situation....I was planning on a Dana 60 swap later on but all the parts are locally available and will be scrapped at the end of next week, so I need to act fast if I want to save this one.
MY truck is an 87 F-250 4x4 with a ZF-5 in it from the factory.
The potential parts truck is a 91 F-350 4x4 with a recently snatched ZF-5.
My questions:
1. Can I decode either VIN # to find the gear ratios and/or how do I read the rear end tag on these trucks. They're not as simple as the older fords. PLUS it may e the fact that the tags are bent and worn so maybe the numbers are flat.
2. What all do I need to grab? I'm thinking just the leafs, axle and steering bar????
3. How much height will I gain from the 350 springs? Like an inch? Because I just want to level it out. Mine looks like it has a saggy front end :/
Anything and everything I need to know is appreciated. I can snatch the whole setup for $150 I think. That's if I can talk the wifey into it hahaha! Christmas makes everyone's wallets a little on the empty side
My questions:
