tbowker
Hudson, Florida
The snow and ice was the best thing that happened to this city, kept all the weirdos off the road.
In the mid 1970's it snowed in Florida, my parents had moved here a couple of years prior. I didn't realize then that snow in that part of Florida was such a rarity. It took me most of the front yard to make a snowball, but I persevered. The only wheels I had at that time was a bicycle.... no cupholders.
MC770
Adams Count, PA
Didn't really do much with it. Drove it over to Lowes to pick up some pipe for a sump pump and paint for the basement project. First time the trucks been driven since around thanksgiving, fired right up without issue (odd for it, usually needs a little ether after sitting that long with the fuel issues I've got) and really reminded me how much I'm ready for summer time to come back around so I can drive it more regularly without having to worry too much about the salt...
Yeah cause they can't do the basic math of recessing them ONCE, vs fixing them every year... people without wisdom drive me crazy. Short-term thinking.
That's an excellent explanation of government thinking.
on Round here we got 3 kind of drivers in/on snow & ice.
1. Old timers been here for a while & know how to drive on snow & ice.
2. Scardy-Cats.....those imports that never saw snow & ice cept on TV. They drive scared & drive 5-10 mph & screw up while others driving 20 & OK
3. Idiots that think they got be first one there. Driving a new all wheel drive car with new paper plates in the window, driving at 60-70 while everyone driving 20-30
I've seen all three kinds around here too. The best part about driving a truck with a 1000lb engine in the front is the incredible traction that all of the weight gives you on the front end. Unless it's wet, such as slush or freezing rain, I'll lock in the hubs, leave the transfer case in 2hi, and drive almost like normal.
I've ridden my bicycle in the snow a few times when I was younger. Sometimes it was fun, other times it wasn't and walking would have been better.
You're in "Florida", I'm in NW Florida which is more like south Alabama and Georgia (except the Yankees that live towards the Gulf), but I can remember a couple inches in 1991. As well as a dusting last year and don't forget "Ice storm Leon" in Feb of 2014 when there was ice on Pensacola beach, there's a couple YouTube videos if you look that up.
ttman4
Last Nite's Dream..
Not that far from you @Jesus Freak & Pensacola but I don't remember what yr it was (about 1977-78) but I was leased on to C&H Transportation Heavy Haul. I had a big oversise, non escorted load headed over into a Mississippi power plant. I bootlegged it into small truckstop on east side of Mobil, Al, right on the bay, right on the Gulf water.
Big city's had an early morning curfew usually between 7-9AM for permit loads. Either wake up, get with it, get thru town before 7AM or wait till after 9AM.
Anyway I wake up raring to "git with it!" 4" snow on ground & more falling, big wet flakes big as a plate. Nobody in that area had EVER SEEN SNOW OR ICE!!!! I could see interstate from where I was sitting. Wrecks, wrecks, wrecks!!! Very soon interstate was closed & blocked. 2:30PM before I could move & go!!
DrCharles
West Plains, MO
How does that help? The front driveshaft is still freewheeling unless the case is in 4H or 4L.
I did drive my truck home once when the rear driveshaft fell off... locked the hubs, case in 4H, power to front wheels :)
Yep, that's how we react to snow.
DrCharles
West Plains, MO
Got it :sly I tried that once but had rumbling noise above 35 mph even while in 2H. Figure I probably need a couple of front driveshaft U-joints, but keep putting it off because there's always something more important to fix, and when I'm on really slippery surfaces I'm not going that fast anyway ;)
tbowker
Hudson, Florida
Yeah, I'm one of those Yankees who live on the gulf. You're in that part of Florida that stayed connected to the lower 48 when bugs bunny cut Florida loose and sent it to South America. I was riding a motorcycle back from Tallahassee around that time in 2014, there wasn't enough clothes on the planet to keep me warm.
FrozenMerc
SW Missouri
Put a new Brake Booster in over the weekend as the original one had developed a vacuum leak (why do those damn things come un-painted???). I also dropped the forward fuel tank and replaced the sender / pickup as the shower head had disintegrated years ago, and the sender was reading funny. It will be nice to have access to all 19 gallons again and a fully functional fuel gauge. The 3.73 gear set for the rear axle finally showed up last week as well, so next weekend I will be dropping the rear tank and doing that sender and swapping axle gears.
Where do you get new senders at? Mine bounces like crazy and tired of it too.
DrCharles
West Plains, MO
Today I was determined to find out why my hazard flashers didn't work. Fuse intact, flasher itself working properly. But no continuity at the load side of the flasher.
So I pulled the steering wheel and column cover to have access to the combination turn signal/flasher switch. After dismounting the switch, there was the problem - the female wiring-harness contact had been installed too shallow (or had been pushed out by a previous mechanic changing the switch). And the excessive resistance coupled with, (most likely) a previous rancher hooking up way too many trailer lights, had partially melted the plastic and allowed the contact to break the circuit. Glad it wasn't the switch assembly itself.
Anyhow, I Macgyvered a repair with a .187 push-on female terminal. Drilled out the plastic block so I could make solid contact with the prong on the switch. Now it flashes (and everything else works upon reassembly too) :)
That's good work there!
Cv axle
