RavenTBK
Slave cylinder install trick?
So, is there any kind of "trick" that I am overlooking to install the external slave cylinder with its stupid retaining clip?
I've installed the new master, hooked up the line to both master and slave, pressure bleed from the bottom up to fill the master, but now I cannot find a way to get the slave to slide up under the fork.
There is a super strong spring in the thing, beyond my strength to push it back with a finger, or palm. (Same deal with the old slave...excessively strong internal spring requires two hands to push back in, even not hooked up to anything). Tried an angled approach, with the piston at a 45* angle seated in its fork divot, but it still wont budge enough to line up the clip. Even tried a prybar to move the fork out...but thats one strong ass pressure plate.
I can, with two hands pushing, move the piston back enough but theres no real way to hold it back for a long enough time to move from pressing it on the side of the trans to up where it needs to sit. Almost like the straps on the retaining plastic piece are too long allowing the piston to sit too far out.
Any tips?
Any tips?
