Slantnose Conversion
MidnightBlade
Shiftin' Smooth
Johnstown, PA
What all parts would I need to convert my Bricknose to a Slantnose.
I have some parts figured out but don't knw what all I need.
Parts I know I need:
Front fenders
Hood
Grill/Headlight Assy.
Rad support?????
I'm only worried about things on the front of the truck, the back is all aluminum now ;Sweet
windshield cowl. the lines may not line up. see pic. yours will be the direct opposite on what you see. hood will have a raised line and the cowl will be flat.
G.W BUFFALO
effort, pa
My buddy just scrapped a complete rust free 86 clip, coulda got it for you for probly 100.00.. I knew i shoulda bought it from him, dam thing coulda been saved.
Danoflapper
Zeeland, Michigan
I converted mine from OBS to Slantnose late this summer. I used the diesel OBS lower hoop with my gas slant nose upper support. That works really well; just a lot of spot welds to drill out. Also, you're going to want to use a cut off wheel to notch and bend the lower flange on the fenders so they will bolt up to your cab. You'll see what I mean when you get your parts together. Everything else is simple. I had the front clip on and off a few times. :)
http://www.oilburners.net/forums/showthread.php?t=48770&highlight=Bricknose
dented73
