Aug 26, 2017 #1 Fordfan90 Full Access Member Joined Feb 12, 2017 Posts 377 Reaction score 20 Location Idaho Does anyone know of a shorter alternator belt? Mine came lose today and started slipping really bad.
Aug 26, 2017 #2 rhkcommander Full Access Member Joined Feb 9, 2010 Posts 2,603 Reaction score 90 Location Oregon Someone posted a topic just a few days ago with pictures... But it also sounds like your tension bolt wasnt tight enough.
Aug 26, 2017 #3 Fordfan90 Full Access Member Joined Feb 12, 2017 Posts 377 Reaction score 20 Location Idaho rhkcommander said: Someone posted a topic just a few days ago with pictures... But it also sounds like your tension bolt wasnt tight enough. Click to expand... Thanks! I'll look around on here and see if I can find it.
Aug 26, 2017 #4 laserjock Almost there... Supporting Member Joined Nov 20, 2012 Posts 8,841 Reaction score 3,130 Location Maryland This is the short one that just goes around the WP and Alt. You must be registered for see images attach
Aug 26, 2017 #5 Fordfan90 Full Access Member Joined Feb 12, 2017 Posts 377 Reaction score 20 Location Idaho laserjock said: This is the short one that just goes around the WP and Alt. You must be registered for see images attach Click to expand... Thank you for this.
Aug 26, 2017 #6 laserjock Almost there... Supporting Member Joined Nov 20, 2012 Posts 8,841 Reaction score 3,130 Location Maryland No problem.
Aug 27, 2017 #7 IDIoit MachinistFabricator Supporting Member Joined Aug 26, 2014 Posts 13,324 Reaction score 3,897 Location commiefornia FYI I buy belts quite frequently, you can get them in 1" increments, sometime even 1/2"
