Alright guys, getting ready to pick up my head studs and valve springs in the next couple of days, Comp 910 as the title says. Been searching to try and find the procedure for changing the springs without pulling the heads, seems I saw somewhere once that you could bring the piston for a given cylinder to TDC and the valve would stay mostly up. What is the crank/balancer mark position for each cylinder? Also I've seen that these are supposed to be shimmed, I didnt order shims so would I gain anything by putting them in without shims?
