Comp 910-16 Springs and Valve Rotators?
bulletpruf
San Antonio, TX
I'm installing the Comp 910-16 valve springs this weekend (7.3 IDI with Stage 1 turbo, 90cc IP, head studs, etc). I understand that the springs need to be installed at 1.8" so I may need to shim to get that height. What about rotators? I have these on exhaust only. Should I plan to reinstall the rotators?
Thanks
Austin86250
idaho
a quote from justin at r and d " comp cams 910-16... you can set them to 1.800' height for ideal seat pressure, but dropping them in as is is still way better than stock."
bulletpruf
San Antonio, TX
Thanks. Actually gave Justin a call yesterday. He said intake may be a bit tight (slightly less than 1.800") but that's no big deal. He also said to reinstall the rotators.
Scott
