soggybottom
Truck sat for a few days while on vacation. 24 degrees out when I tried to start it. Glow plugs cycled for about 15 seconds and the truck wouldn't start. Tried cranking in 10 second bursts with a break in between, and couldn't get the truck to fire. Tried this probably 4 or 5 times. Finally plugged the truck in for about 30 minutes and it fired right up, ran at full throttle for a split second, then ran normal.
I have been fighting a hard start issue since I bought the truck. It has new glow plugs, new return lines, new fuel filter, new battery cables, old batteries but they passed, new alternator, new starter, new voltage regulator, facet electric fuel pump. After doing all of this the truck starts better, but after sitting a while, or when real cold (30 or under) it is hard to start. This is the first time I haven't been able to get it to start at all.
Seems like a glow plug issue since it starts right up after being plugged in, but the plugs all pass the light test, the controller and relay both passed all the tests, and the harness is good.
I am losing my mind here. Any help appreciated.
