Power steering pump driven by a belt direct off the engine.. or by a 110 volt electric motor ... or by a DC motor rated for continous duty....
The power steering pumps are mostly all vane type pumps and will move oil... cold or not. to lower pressure, use larger hoses for pickup and delivery sides, play with pump speed by the size of the pulleys on motor / pump...
In my experience, most folks that have WMO for free want it picked up without fuss or mess and usually have either tanks [some large ones] or 55 gallon barrels. When you pump down their waste oil put a ball valve on the pickup end and the "into your tank end" so when you stop pumping you can close the ends and seal the system... ... if you leave a mess,,, you won't be invited back and you mess it up for the rest of us.
Gett'r Done. Power steering pump from you local pick and pull yard shouldn't run you more than $20 or so..... 1/3 hp electric motor.. so pullys,, a belt... hose [1 inch white swimming pool pressure hose works... See Home Depot]... ball valves [2]... 1 inch plastic pipe and elbows to make stingers to go into tanks. [cut the tips at an angle so you won't suck the stinger to bottom of tank] Look around, someone has clean 55 gallon barrels for $10 or so. Get some.
If you use an electric motor, use a small 1200 watt generator to run the motor... you can pick them up for less than $150 [try Harbor Freight on sale].
Pump it, filter it.... run it... messing around with truck fuel pumps to transfer oil is a waste of time and money... you want to be in and out in 20 minutes and come back for more later...
