running *** ( or waste transmission fluid.)
Natehimself36
Oregon
I officially started my alternative fuel adventure. Drained a gallon of CVT fluid, a quart of Honda Dual pump fluid (DPF), and five quarts of 0/20 motor oil into the clean dedicated container. Ordered the Ultimate Force Centrifuge from PA Biodiesel today. I will be planning how I will set everything up. I have an ample supply of
55-gallon drums so they will be my storage container of choice.
Awesome good for you! I love my ultimate force fuge. Some guys only do one or two runs at a slow rate ( 3 gph) give or take a gallon. I do multiple. I keep running it over and over until i get very little sludge from the oil. Lettting it settle a month or two helps a lot.
nhwrench01
new hampshire
well, things are f/n cold here in N.H.,, so, no more running on ***. I can and have thinned the oil with diesel before, but its a toss up on how much to thin it, as to how cold it is,,, and id rather not starve the pump or stall out, so I just run straight diesel for the winter..
But, I would love to get a "fuge" set up. just to much $$ right now, I do let my *** set for months, then run it through a 1 micron sock filter .
not that I have tons of money, but the way I see it, my truck was stock, non running and most likely not maintained well when I bought it, everyone says the pumps should be changed by 150k or so,,injectors also.. I have 180k now, bought it with 140k on it and its going strong, so if I experiment with *** now, when I replace everything , ill be good to go.
On a side not, I have mixed my *** with gas. very small amounts. about a 1/2 quart to 5 gallons( if I remember right). .. maybe its to much,maybe it was to warm that day, ect,,, but 1/2 way to work(22 miles one way). the truck started skipping , chugging, then stalled,, all with in 3-4 seconds. I switched to clean diesel and I started in afew .. maybe it was me or not, but I will never use RUG again...
YJMike92
NW Arkansas
I have let all my *** and WMO sit for long periods and it amazing what settles to the bottom of the barrel. It is a good way to get rid f a good amount of contaminants. The one-micron filter should catch the rest of the harmful stuff. Seeing what settles out was the reason I decided on a centrifuge. I'd rather be safe than sorry.
YJMike92
NW Arkansas
Making some progress on gravity feed into the centrifuge. The barrel will lay horizontally on a stand about 8 feet high and gravity feed into the centrifuge. I welded a 1" bung into the top of the barrel a couple of inches above the original 3/4" bung. The new 1" will feed the centrifuge. The 3/4" will be the sludge drain. The original 2" hole will be the fill hole. I welded a 3/4 inch bung onto the side to serve as a breather. I hope this works otherwise it's a lot of wasted time.
nhwrench01
new hampshire
well, things are going good,,, till now.
Not sure how it happened, but I've got water in my tank, (rear tank,) . it had to be a oversight( duh) on my part in collection buckets,mixing,pouring , filtering...etc...
Had about 1500 miles of free driving, then the "filter" light came on,, no problem.. clean the glass filter just before the electric pump. ( new pump now,holley red) and im off...
1/2 way to my camp, the light comes on,, switch to front tank(clean diesel only) and keep going.
4 miles later, the light is on, cant go up hills fast,bucking, surging...
take my time, go slow. get to camp. remove spin on filter,drain and reinstall. great, all the way home. replace filter and 15 miles later, the same... anyway, found ive got water in the tank,,,
drain tank and im going to fill with clean diesel and carry 2 spare filters with me till it cleans out..
My point. it can happen.. i read once on a carburetor rebuild site." cleanliness is godliness."
just be carefull, never thought id be the one fighting this problem, but,,,
nhwrench01
new hampshire
well, found after draining my rear tank( atf ). filling with clean diesel, my "filter " light still comes on. only after driving 35-40 miles. i switch to the front tank,,, only clean diesel ever.. and i get 5- 8 miles . then the fuel filter comes on . again.
i have a new , holley red fuel pump, glass fuel filter just before it and stock filter at the engine.
ive changed the engine filter 3 times, ( only after the light comes on) and i get 35-40 miles, then,,, its on and last time even idling it did not go out running on clean diesel.
i did run fuel into a can ( after the pump /before the engine filter.) from the clean diesel tank. and after sitting awhile. it looks like ive got water in my clean diesel tank ..
i have 2 new filters with me , a new glass cleanable filter before my pump/ glass breaks when its dropped. i will take my chances and drive it to work and home. 21 miles one way... hoping to run the clean diesel tank down and fill at a new station this week. ...
nhwrench01
new hampshire
Did you figure your problem out?
I believe I did, I had water in my clean diesel tank from the gas station... I added 1 quart of 911 to the clean diesel tank with a 1/4 tank in it. After 1 more filter change, I've got about 100 miles so far with no problems .. I had to keep cleaning out the small glass filter before the electric pump as water would settle there after sitting all night.
so far , so good. I've even been running on the hiway at 55/60 trying to use fuel and make my light come on... all good,,,,,sofar...
Alleycat
