Running on oil
millertime
washington state
So can I run 100% used oil. Do i need to heat it. I am about to have an 89 1.6NA and I would love to run it on 100% used motor oil.
oworm
Indianapolis IN
Putting used engine oil in a fuel injection system is a recipe for eventual disaster. Used oil contains soot,carbon and metal deposits. Diesel fuel injections systems must be kept as clean as possible for optimum performance. Using clean oil is fine. I use a pint of unused 15/40 or 2 cycle mixed with PS Diesel Kleen on every fill up in my truck.
subway
be nice to the admin :D
York PA
look up the systems to run WVO and that is basically what you will want to run WMO. WMO is more forgiving as far as temperatures go but you will still not want to be starting on it.
Lance
