'86 6.9 with Banks. New pump and injectors maybe 4k miles ago. Had some air intrusion sometimes when sitting overnight or longer. Gonna go over returns yet again soon. When I changed orings after running a few times one injector loosened, I retorqued it. Have a slight exhaust leak seems more noticeable when hot. After installing new injectors and ready to fire I noticed two copper washers missing from the old injectors, didn't see any in bores before installing new though. Double checked the injectors that were easy to get to with everything on and couldn't find them. Could be double washers on two, or maybe I dropped or lost them. Head gaskets are original so far as I know. I might be going crazy but it feels like when the engine is up to temp the idle is very slightly rough. Perfectly smooth before full temp both on and off cold advance. Puff of smoke on startup and when cold it will have a slight visible haze for a minute or so until there is some temp in it. Aside from that no smoke unless hammering down before turbo spools.
What could cause a very slight rough idle only when up to temp? Should I get more washers and go over injectors again? Could it be from air intrusion? Head gaskets? Exhaust leak messing with my mind? Something else? Truck starts easy and has good power, no issues aside from hot idle not feeling quite 100%.
