IMO, nothing you pour in the oil will help compression. I have had good luck with Delo, wally world oil, and mobil, even penz diesel grade didnt burn. SOmething about the NEW rotella isnt kosher.
T
1000 miles into my fresh oil change, I am down one full quart.
Only a quart? My truck ate 2 GALLONS in 1000 miles
Here is what I think of Rotella
I switched to Valvoline had it hasnt used a drop
Who makes the supertech oil? I didn't know any better so i've been using Rotella (it was teh cheapest non-walmart oil). but if the sepertech is really that much better than i'll switch. Got an oil change coming up too...
We ditched Rotella completely at the yard which is a shame I have used it for better than 20 years now. I'm running Delo 400 in my personal stuff and we run lubriguard in the buses. Shell changed the formula in Rotella about 5 years ago and it hasn't been worth a damn since. I can count 8 engines I know of personally that went out and it was proved it was the oil breaking down prematurely that caused it.
rotella has consistantly tested out thinner and burned off faster than other test oils, this isn't just the imagination of IDI owners. It has to do with the makeup of the oil. Rotella has a larger percentage of it's volume being made up of detergents, which means that something has to be left out and that something is oil. Rotella will clean better than other dino oils, but at the expense of lubrication protection. For an engine with any kind of wear or one that has a certain amount of consumption built into the design of the valve system, rotella is a recipe for consumption. Similar to running a light grade synthetic, it's going to find its way through the gaps and get consumed. If you don't want your oil to get consumed, you need something heavier and that means something with less detergent thinning out the mix.
usually the ones that do well on rotella are fleets that run up north and run cummins engines which have a limited service life anyway and run teh stuff since new. Those are teh folks they have doing their boasting for them The things will make it to around 350k to around teardown time with minimal usage ( or these days usually trade in time ).but don't try to put that stuff in an old Cat with a half million miles on it or you can practically watch it blow out the stack
