and a huge lack of mechanical knowledge!
its ok tho i dont mind helping!
but i gotta be an A-hole and point it out
the picture if the flywheel you have in post:
http://www.oilburners.net/forums/sh...ch-Flywheel-SMF-Rep-Kit-Hints-and-Suggestions
post #1?
that is the back of the flywheel. it goes on facing the engine.
remove old pilot bearing. install new pilot bearing( before install, make sure it fits on the front part of the input shaft of the transmission)
the clutch disc, will only go in one way.
use the clutch alignment tool to hold it somewhat in place.
then you bolt on the pressure plate.
make sure you tighten the bolts evenly.
1-2 turns per tightening "sequence".
the tightening sequence (pattern of bolts to tighten)isnt important.
what is important is that you draw (tighten) all of the bolts equal amounts per sequence.
this will ensure that the clutch plate tightens evenly on the clutch disc(to the flywheel), and there will be a point where it will barley move.
this is when you make sure that the clutch disc is dead center
clean the input shaft and collar of the transmission
use bearing grease on the splines and collar.
install the clutchfork and throwout bearing.
operate the clutch fork back and fourth
make sure it moves evenly and smoothly.
then insert 4- 6" bolts into the engine adapter plate.
lift transmission into place, making sure the throwout bearing and clutch fork still works, and it didnt fall off.
slowly move the transmission twards the engine with it in any gear.
you will want to rotate the tail shaft to align the input shaft to the clutch disc.
you will need to wiggle it a bit to get the front of the input shaft to seat into the pilot bearing.
once its close, install 2 bolts, remove the 4 6" bolts you put in previously and tighten her up and finish it!
