If the hitch is off of a 2nd gen and your Ford is the same as my 92 F250 it won't fit without modification. I just looked under my '99 dodge and '92 ford, the bolts are in different places. The OEM dodge 2nd gen hitches are not very good anyway, I have seen at least 6 of the pre recall hitches (recall was sometime after '99) crack in the bend near the rear bolts. The pre recall hitches only have three bolts on each side, the later ones added another set of holes to the rear.
