askikr79
i am looking for input and ideas on how to rebuild my water separator.
its a 1990 7.3. i have been searching the threads for days and this is what ive come up with.
i want to remove the heater and put a bolt and jb weld in its place.
remove pressure switch and install a gauge. haveing trouble finding a liuid filled one i like.
replacing the check valve. thinking about plugging it.
replacing schrader valve.
removing water in fuel sensor. plugging that hole with maybe jb weld.
plugging check valve on bottom.
rethreading drain on bottom and installing a 1/4 ball valve.
installing a duralift facet pump next to and install new hose to the filter. also considering installing a hose to the injector pump. trying to eliminate those " olives"
if anyone sees a way to improve what i am considering. please let me know.it helps me brainstorm.
if i remember i will probably takes some photos when i am making the modifications.
