ive seen 13" daytons with 8 lug
or was it 2 different 4 lug patterns?
gotta have the whitewalls tho
I spent a year fixing a cab I know will have to be either swapped or fixed again because I'm a moron.
You missed the part where the whole dash is different? With its mounts welded as part of the firewall, and bunch of other stuff too... So he either needs the OBS dash as well with all the electronic BS that goes with it, or like you said cut and weld... Which idk about you, but to me if he's gonna be cutting and welding might as well fix the cab he's got now, then at least he won't be throwing hundreds of $$$ away.contrary to LCAM, i would purchase the OBS cab.
two ways you can do this....
you can swap the whole cab,
changing to OBS engine harness,
or
just using the stuff from the OBS, cutting out the entire side of the truck and putting it on yours.
Also, on the front side of the firewall, it's not the engine harness that's the issue, it's EVERYTHING! About the only thing OBS and bricks have in common there is the heavy cables for the batteries, all else will require repinning connectors and cutting and splicing. Which admittedly isn't that big of a deal, but it is time consuming, and definitely not work for wintertime in unheated garage...
thanks for the input junk.
yes the B pilalr itself is relatively untouched, i came in on an angle and the tree basically crushed in the very top roof part.
my worst concern is windshield area/a pillar. Like I mentioned earlier the firewall got pushed outtowards the front as the upper part got pushed in. Heres a pic to show it a little better, hard to tell but there is about an inch gap between the dash adn the cowl now.
You must be registered for see images attach.
as for pulling these areas out im planning to weld a plate to the area where the front door attaches to with a hook on it, and attach my pulling devise to that. pull at an angle towards the front to simulate the opposite of the imact.
also saw why the rad was leaking, fan contacted it. It was small clearance to begin with, and it seems the rad jsut moved for aft in the impact tha *** touched the fan. front end looks straight.
i will get you #'s today.
i have the trim on my windsheild, hope i can get it off today as well, as they need to be powder coated
