Where can i get a new one of these guys? the little stem the the hose goes through broke and it leaks coolant? how do i repair it if i cant find a replacement?
To make room for my third battery, I had to relocate my washer fluid resivoir and coolant overflow. I made the overflow out of PVC. Easy enough to do, just costs more than the stupid bottles from advance auto.
yeah that should work fine... Overflow tanks are just that... a tank. I just got a universal one by Jegs I think from my local offroad racing place. As long as you have a place to mount it and some tubing to plumb it in.... it should work fine.
The mention of making one out of PVC I assume they mean that they built it out of large diameter PVC pipe from a home improvement store. All you need is some large diameter (I would guess 3-4" +) and some caps and a way to plumb connections on it.
#1 in the pic is a vent hole at the top. I also have a sight tube running from the bottom of the assembly tapped in with a 1/8" elbow and running up with a small vent hole in it so I can see the level without opening the cap. I don't have a picture of that though, and its too dark.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
