radiator overflow bottle
gatorman21218
Ashland VA
Where can i get a new one of these guys? the little stem the the hose goes through broke and it leaks coolant? how do i repair it if i cant find a replacement?
emmer
Canada
I left a soldering iron (hot) on mine and burned a hole thru it, so I patched it with
~shoe goo~ That stuff is beyond strong!
I don't know if it's avalible in the US though.
Andylad13
DieselBoy
Connecticut
To make room for my third battery, I had to relocate my washer fluid resivoir and coolant overflow. I made the overflow out of PVC. Easy enough to do, just costs more than the stupid bottles from advance auto.
The only source for a factory new one that I am aware of is LMC.
jperecko
Diesel Ape
Boonies of SoCal
yeah that should work fine... Overflow tanks are just that... a tank. I just got a universal one by Jegs I think from my local offroad racing place. As long as you have a place to mount it and some tubing to plumb it in.... it should work fine.
The mention of making one out of PVC I assume they mean that they built it out of large diameter PVC pipe from a home improvement store. All you need is some large diameter (I would guess 3-4" +) and some caps and a way to plumb connections on it.
Andylad13
DieselBoy
Connecticut
#1 in the pic is a vent hole at the top. I also have a sight tube running from the bottom of the assembly tapped in with a 1/8" elbow and running up with a small vent hole in it so I can see the level without opening the cap. I don't have a picture of that though, and its too dark.
gatorman21218
Ashland VA
Thanks but i think i'm just gonna keet the old one unless anyone can tell me if that bottle needs to be pressurized to work
