Radiator Fan
Mikes91
Melbourne, FL
Yet another technical question (sorry, just looked under the hood and reminded myself that some things need attention).
My fan blades are about 1/16th of an inch from the inside top of the fan shroud, and rub occasionally.
How far SHOULD they be if the engine is placed correctly?
Why would the engine move? Motor mounts are fairly new (about 18 months, tops) and I've already had the engine moved back into correct position once because the trans shop moved it somehow when replacing the trans.
I don't know how the mounts work... is it likely to be something simple like "mounts weren't tightened enough"?
Thanks again,
Mike
argve
Resident Fruitcake
Gwynneville, Indiana
Thanks again,
Mike
There is a little bit of slop in the fan shroud to rad mounting holes... try sliding it a little. There is also a little bit of slop in the rad to rad support holes but typically I just let it rest on them then just adjust the shroud so that everything clears...
Mikes91
Melbourne, FL
Thank you... sounds like I might wanna try moving the *EASIER* item FIRST, eh?
Mikes91
Melbourne, FL
By, "a little bit" do you mean 1/16th of an inch? I looked at it today and didn't break out any tools but it doesn't look like there's much room for movement of that shroud on the radiator mounts.
Mike
argve
Resident Fruitcake
there is probably 1/8 of an inch between what the spring clips allow on the rad and the bolt through the holes on the fan shroud. If it clears it clears so just slide it up a little and enjoy.
Mikes91
Melbourne, FL
Cool... I'll check it out this weekend.
Thanks again,
Mike
DIESEL_COP
JASON HALOUSKA
NEBRASKA
Thanks again,
Mike
If your motor mounts are like mine the mounting studs sit in a upside down tear drop. I dont think they would move unless they are broke, could be wrong though.
Mikes91
Melbourne, FL
Just replaced the mounts last year... shouldn't be broken!! I know it was the trans shop that caused the problem... not sure exactly how... but will try to fix by moving the shroud as Travis recommended.
Mikes91
Melbourne, FL
I *tried* to move the shroud up just a wee bit last night, and it moved MAYBE 1/16th of an inch. Not very substantial. Found one broken bolt that I'll want to replace.
Is it possible the entire radiator slipped a little downward? Is it possible the motor mounts may be holding the engine high because of an adjustment issue with them? I'm leaning toward the radiator being mounted just a little farther downward than it could be... but who knows... Not sure if there's really any positional adjustment in the motor mount assembly, as I've never had to deal with it myself.
Thoughts??
Thank you,
Mike
Mikes91
Melbourne, FL
JPR said:
Mike,
Did you inspect the body bushing and shims between the frame and radiator support?
Nope... I'll have a look. Where are the body bushings located? Do you mean the cab bushings? When I had the other bushings replaced 18 month ago, the cab bushings wouldn't budge... so they stayed in.
The radiator bushings were replaced about 18 month ago.
Thank you for your suggestion...
JPR
Fort Worth, Texas
Mine is 7/8" from the end of the fan blade to the shroud. Enough to slide your fingers in between. Are the shims missing on yours?
I knocked the shims out on my 83 when I dropped the nose into a 3' deep irrigation ditch. I got shims from a body shop and and slid as many as would fit into the space. Then loosened the bolt and added another 1/16" or so, then retightened the bolt.
bossviking
