Question on onboard air.
rjjp
Needs to go test
Clare, Mi
Ok guys, I have an air compressor I pulled off a F1000 (yes, F one thousand) dump truck which was equipped with air brakes, so there is no clutch on said compressor.
How bad of an idea would it be to install this on a daily driver the way it sits?
Should I install a clutch off an AC compressor (if possible)?
Or should I just keep looking for a York?
rhkcommander
Oregon
could just mount it and not put a belt on it until needed :dunno
not having a clutch would rob power and fuel efficiency, so if you really need it hook it up but if not why bother
RLDSL
Diesel fuel abuser
Arkansas
You might want to do some checking around a big truck boneyards and see if someone knows anything about that compressor. With no clutch, it may have an internal bypass preset at a certain pressure that cuts out and back in when the pressure drops below a set threshold.
hesutton
The Anti-Anderson
Bowling Green, KY
If you can find a clutch for it, that's what I'd use. You can control it with any compressor switch. NAPA should have a catalog with different pulley/clutch options for that compressor, but you'll need to know what model you have. Is it a Bendix?
Heath
Seven4eight
