question about injector return lines
hjalbert
My injector return lines are ragged, and I do not think theya re assembled correctly. I found a post on this site that links to new kits. cool. My question regard the flow through the lines. my set up has the line going from right after the filter to between #1 and 3. then the cross over line goes over tees into the return, and continues to imbetween #8 and 6. all of the ends (1,7,8,2) are capped off, some with a bolt and hose clamps. Some are leaking. I wanted to know mostly about the line that comes from after the filter. Anyone know which directions the fuel is flowing through these lines? thanks, John
just to note I have all the lines going from injector to injector. I only detailed where the tees are. thanks
placidoert
