Quad o-ring for zf5 master/slave
DeepRoots
Tug Engineer
Douglas, Georgia
Man being gone for a month at a time sucks.
The list the mrs gave me before I got home:
1. VW is defueling randomly and generally sucks
2. Lawn Mower doesn't work
3. Septic System back up, she fired up a neighbors backhoe and discovered entire drain field is clogged with roots.
4. diesel truck is dead
I got home a few days ago,
1. We did a road trip to Orlando (6hours from home) where I found a shop that'd let me work in it.... found vacuum hose to VW turbo was split... replaced it.
2. Fixed lawn mower... had to rebuild starter and clean/reset ignition junk as it was rusted.
3. Been raining, so I haven't replaced the drain field on the septic yet.
4. Diesel truck battery's are dead.... plus I stepped on the clutch and blew out the quad ring on the master cylinder, it's toast....
so the question is!
Where the hell can I get one of these ***** rings? or at least does anyone have the size/name of it so I can order it from McMaster?
I tried to find one locally a few years ago and everyone looked at me funny when I mentioned what I was looking for.
thanks,
Drew
hesutton
The Anti-Anderson
Bowling Green, KY
Drew, it sounds like you've got a nice "honey-do" list there. I don't know the dementions of that particular ring, but I bet you can find it on this site and they seem to be pretty cheap.
Hydraulic Warehouse
Hope that helps.
Heath
typ4
Newberg,OR
Remember it must be brake fluid compatible.
taylerperson
