02x72
Looks like Ive got a blown head gasket( not getting to operating temp, loosing coolant, blowing white smoke) so Im gonna have to pull the engine here soon. Unfortunately taking the front clip off the truck is not an option, so its gonna be done the hard way. I plan to replace everything associated with the head gaskets obviously, send my pump into Mel to be fixed, send my dying starter into DB Electric under warrante and replace a dying booster all at once. Is there anything else I should consider doing while the engines out aside from cleaning it real good and painting it a nice IH red? Im thinking a new timing cover gasket and possibly re-sealing the oil pan even though neither appears to be leaking, with a 23 year old engine IM sure they will start as soon as the motor goes back in. Any other suggestions from guys that have done it?
