PTO install discussion
crash-harris
Breaker! Breaker!
Chillicothe, OH
Custom fab one up or do what I did on Bruiser. Had a leftover class 4/5 rear receiver from a parts truck once upon a time and I cut the rear support arms off and made brackets to mount it to the front frame with some thick angle iron. Not sure if it'll interfere with the diesel core support though as Bruiser is a gasser.
Use the coupon and get another 20% off. Your coupon might be for that specific winch tho.
crash-harris
Breaker! Breaker!
Chillicothe, OH
You can only do that if you buy it in store. The website doesn't allow you to use 2 coupon codes on the same order, regardless if it has anything to do with the same product or not (ie: cannot use "free item with purchase" code and a 20% off coupon, but they let you do it in store).
steelheadguy
Registered Idiot
Southern Oregon
Took the bumper off. Im thinking about bolting a square steel tube to the frame and then welding a receiver under that. Can anyone think of something easier?
m2rtin
