project: watch out Kentuckians
no mufflers
rhode island
while i was on it i did the carrier baring. it has been long due and the rubber was all warn out and it was getting noisy.
i noticed i have the smaller size baring. i was hoping it would be the larger one. does anyone know what model trucks had the larger baring?
no mufflers
rhode island
I got some headway on the hood and some other odds and ends. today I sorted some wires for the trailer harness, it has needed to be done for a while now. I finally put new window seals in the front doors, just the in and out scrappers and the strip that goes in the window frame. I still need them for the back so its added to the list.
I mounted the hood for another test fit. the last thing to fab on it are a few little braces and a frame that surrounds the IC. it will mainly be there to funnel the air on the IC rather then spreading it all over the place. the more I look at the more of a pain in the ass it will be, but I think it will help a lot with the air direction.
the ford emblems on there are staying chrome but the big IH emblem will be molded into the hood and painted black. I think it will make it blend in nicer not look too busy.
shawn deere
nebraska
I can only imagine how much air thats going to funnel based of the lil triangle window...
no mufflers
rhode island
I wish I had a number to give you. it seems to cool it a fair amount so I would guess a lot of air but im not even sure how you would measure that.
anyone have a wind tunnel with that fancy visible air?
shawn deere
nebraska
I bet its a lot!
I can stick my head out the window if i really want it quantified lol.
Looks awesome too
Think the air lifts on the hood? Just pondering if itll break the hood latch going into a head wind
DaveBen
Ukiah, Ca
I would bet the scoop puts a lot of lift on that hood. Better have some strong hood latches!!
Hate to see you traveling down the freeway and the hood blow open. That would suck.
no mufflers
rhode island
I have been doing some routine maintenance on the truck just to check it all over. such as, a full grease job, check frontend parts, rebalanced all tires, top off all fluids, tighten all hose clamps and im sure a few other things.
I have the hood all done in the metal fab department. the inner structure is all done and welded up. its not perfect and I would change a few things but it will work and I just need to get it done. I don't have much time so ill get as much primer, seam sealer, bondo and paint on there I can.
pictures to come.
no mufflers
rhode island
picture time!!!!!!
all I really have are some under shots of the hood frame. I don't have much time but ill do what I can. at the end ill have a action shot. that's the trailer ill be towing, also just finished it.
Pullet
New York
I'd measure underhood temp, put any slow-reacting thermometer under and drive it around. Won't give a comparison unless you have an unmolested hood to swap in or old data.
Bradz
