Project Truck - 89' F250
renjaminfrankln
Raleigh NC
Here is my '89 F250 that I picked up last Friday. Its a 4x4 XL with 7.3 IDI, first gen banks turbo, ZF5 transmission.
It was a plow truck for awhile and was pretty dirty when I got it.
Plans include in somewhat particular order:
  • Fix sagging front leaf springs, replace shackles, bushings etc..
  • Fix steering slop and get alignment
  • Air intrusion issue - probably needs new injector pump
  • Change fluid in front/rear axles, xfer case, transmission
  • Fix fuel selector issue and senders - currently have just the front tank working with no senders
  • New 265/75/16 tires and wheels
  • Fix small dents with bondo and touch up paint, replace tailgate hinges, compound and wax paint.
  • Interior - swap in later model 92-96 bench seat with headrest, recover if needed. Remove vinyl floor, add sound deadening material, replace with new molded carpet floor
  • Fix heat/ac.. heat first, AC over the winter.
  • New door seals etc...
renjaminfrankln
Raleigh NC
Here it is with new leaf springs and shocks. Getting new tires on Saturday 265/75/16 on AR 16x7 alloy wheels.
Quite a drastic difference with the new springs/leafs/bushings! Rides great now.
Thewespaul
Bulverde, Texas
Looks great! I’m a big believer that everyone should have a thread for their truck if they plan on keeping it for a long time. It becomes very valuable if you ever need to use your insurance since all your work/time/money is documented well in one place, and it helps with the “when did I change this”.
Lookin good, I really like that color on the single cab.
renjaminfrankln
Raleigh NC
New wheels and tires. The wheels are 16x7 AR Outlaw II with a 3.7” backspace. Tires are 265/75/16 Corsa Highway Terrain. I usually buy name brand tires but these were only $92 each so I figured what the heck. They are E rated.
renjaminfrankln
Raleigh NC
THanks! And thanks for your help!
By the way the front springs lifted the front end a bit too much. They’ve only been on there a week. I’m wondering if they’ll sag a bit or if I need to install some offset ball joints to get the camber correct.
Thewespaul
Bulverde, Texas
They will sag a bit, but I wouldn’t count on it, if they are oem replacements they shouldn’t need anything special to get the alignment correct. How do the pivot bushings look?
renjaminfrankln
Raleigh NC
They are 3486lb springs part # 43498 on rock auto
Appears there are also some more expensive 2750lb springs that is probably what I should have installed.
Oh and the axle pivot bushings actually look fine.
renjaminfrankln
Raleigh NC
Hmm, have you gotten an alignment after the new leafs went in?
Yeah I had a shop down the street throw all the parts in and do the alignment. Its off by a fairly significant amount. The front end sits a lot higher now. The shop owner said if it does not settle out in a few weeks I should put some adjustable cams in the upper balljoint mount. I spent a little bit of time looking this up and I think it can be done.
The_Josh_Bear
Western WA
Yes it can be done and it's what they should have done during install... like @Thewespaul said they will settle *a little* but new springs is new springs. They need an adjustable camber nut on the upper ball joint and to be adjusted. That's all I know, my front suspension is pretty square so I haven't had to do it yet!
Don't drive around very long like that on those new tires, unless you like the worn-shoulder look. :confused:
renjaminfrankln
Raleigh NC
They do continue to settle out.. noticeably better from when I got it.
Also, the axle pivot bushings are more roached than originally thought. Those are getting replaced ASAP.
I spent about an hour under the truck just poking around this evening. Also managed to change the fluid in the ZF5.
renjaminfrankln
Raleigh NC
Anyone happen to know offhand the size of the metal brake lines? I need to replace the line that runs from the proportioning valve to the rubber line on the right front brake line. Its looking a little.. crusty
taylerperson
