Project Big Red
tjsea
Lickdale, PA
I'm watching the fan upgrade thread too. I even wondered if putting the 6.4 fan on the idi clutch and trim it to fit in the radiator shroud would help. I also considered making some sort of air oil cooler setup just to try to pull some heat out of the cooling system. Also, where do you guys put your probe for water temp? I'm looking at getting an actual gauge before the rally.
laserjock
Almost there...
I put mine up front where the stock factory sender is. Dr side of the front of the engine. That’s the hottest place in the engine.
laserjock
Almost there...
@hesutton
I seem to remember looking at your truck and seeing you had added extra air dams to force air through the radiator. I’m wondering if the extra heat the turbo is dumping into the system is a problem. I’m also wondering if the volume I’m running through the turbo is contributing factor.
Any thoughts or insights you have would be appreciated.
I would have to wonder how much it would help adding the bumper cutouts like the psd have.
I mean, that's an extra step, not like ford would do it if it were for not.
They also had somewhat of a rubber mat/dam? Between the bottom of the bumper and core to help direct air...
laserjock
Almost there...
Yes bumper is cut out already.
I am going to try some air direction first I think. Problem is it only does it loaded heavy and working hard so it’s going to be tough to see results. It’s a hike to get to a big enough hill to really work it.
catbird7
PA
I know you already changed fan clutch however is it possible you got a bad one? When I changed fan clutch it was night and day regarding cooling ability. Mine doesn't even hint at getting hot now. Sidling Hill with exhaust temps hovering around 1100 and black smoke pouring out the exhaust, coolant temp doesn't even move. Mine does not have inter cooler which may make diff???
Thewespaul
Bulverde, Texas
This is why I mentioned heat soaking, it could be with the intercooler the rad is just getting hot air and not flowing like it should.
laserjock
Almost there...
I’m sure the intercooler in the stack isn’t helping cooling. It was a motorcraft clutch from rock auto. I suppose it could be bad. I swear I’ve never heard it kick in and change pitch.
laserjock
Almost there...
To me if the rad was heat soaking it wouldn’t cool off as fast as it does. Within seconds of lifting off, it starts to drop. To me that says water flow problem. I don’t know. I don’t understand why higher rpm and lower EGTs is giving me higher water temps. That seems contrary to everything I’ve read.
Vinceslamer
