Pressure tubing size ?
93blklightning
Abingdon,Va USA
Ok, I'm working on her again...finally.
I'm still in the process of gathering parts to build this truck.
My question is what is the proper pressure tube size,and v-clamp, to go from the turbo to intercooler, or just to the intake snail ?
Again, I'm fitting a 1995 PSD, Garrett GTP38 ...i think it's a 1.10 ar, to a 7.3 idi. I can't remember if it's 2.5, 2.75, or 3 inch.
typ4
Newberg,OR
Any of those will work. I have 3 inch, if I was to do it again I would go 2.5, way easier to route thru core support. Oh, and I guess I will be doing it again on the dually.
:dunno
93blklightning
Abingdon,Va USA
Thanks typ4, what is the correct size on the pressure side of the turbo for the v~clamp ?
Thanks for the info, I'll most likely go with the 2.5 like you said.
Just guessing....I'd say there's not as much lag as there would be with a 3"?
